So it's been a couple years since I had my 460 built, and I am finally putting it in its final resting spot. In my '78 F150.
Specs off the top of my head:
C9VE block .030 over, D0VE heads, 22cc dished pistons, stock bottom end, Edelbrock Performer 460 intake, Edelbrock 1407 carb, mild low-end cam (can get specs if needed).
Ever since I had this engine, it would never run right while driving. However, while parked I can romp on it and it will sound just perfect all the way up to 5000rpm. I thought it wasn't getting enough fuel because of the 650cfm carb (I didnt know it was a 650 until recently).
Threw on a new 1407...sounded much better all around, with much better throttle response. But it still falls flat on it's face while under a load (driving). Then I got to thinking it's either timing, or the stock mechanical fuel pump is not getting enough to the carb. I'm leaning towards timing.
It was initially set to 9* advanced at idle. I never heard of checking the total mechanical advance until searching on here today. How exactly do I do this?
I do know it probably needs a tune-up (plugs, wires, cap & rotor), as they were all carried over from before it was rebuilt...
I'm just fed up more than anything. I've been working on it for the past 5-6 weeks (including dropping the engine in one weekend and fighting with an unknown flywheel and tracking down a clutch for it for an entire week!) I'm about ready to sell the dang thing or pay someone to set it up for me (which I really hate to do...)
