1 - 8 of 8 Posts
I'm getting closer to my single digit pass. Next outing I will have it. I over the winter rebuilt my trans with a custom converter.
Just ran a 10.04 with a 1.36 60' @ 133 MPH. Still on DOVE heads and no power adders.:eek:
http://youtu.be/70l4WJwMEME?hd=1
Nice. I'm working on a similar build with a 93GT hatch. Can you provide some more specifics on the engine?
Thanks.
Thanks.
69' block 2 bolt main. Scat 514 stroker kit with 6.8 length H beam rods, flat top pistons, DOVE C heads CNC ported with over sized valves, Crower off the shelf roller cam 300+ duration, Miller 1.7 roller rockers Eldelbrock victor Jr. intake with spacer, 1050 dominator, MSD 6al box with billet distrtibutor, Th400 with JW reverse manual/ brake valve body, 9" with 3.89 spool, adjustable upper and lower control arms. Coil overs in front and rear with anti roll bar device in rear.
Thank you. Any idea of the CR with the flat tops?
With my DOVE heads, .030 over bore, flat top pistons and (if I remember correctly) .060 cometic gaskets comes to 12.5 to 1.
1 - 8 of 8 Posts
