I have a 1971 Mustang with a 429 Cobra Jet engine. I just installed a Pertronix Ignitor 2 Billet Distributor, Pertronix FlameThrower 2 ignition coil, and the Pertronix 2001 Relay unit, along with new Ford Performance 9mm spark plug wires. The battery, spark plugs, starter, alternator, starter solenoid, and voltage regulator have also been replaced recently. I now have a no-start condition...
Here are the voltage readings I got with a multimeter tool:
Could I have a faulty ground at the coil?
Any guidance or suggestions would be greatly appreciated. I am hoping that there is something simple that I have overlooked.
Thanks everyone
- Voltage at battery - 12.7 volts
- Voltage (key on) at positive terminal on coil - 12.6 volts (using engine block or battery terminal for ground - no voltage reading when I tried to use the negative terminal on the coil for ground)
- I did confirm that there is no voltage to the coil with the key off
- I checked the ground at the ignitor plate inside the distributor (12.6 volts between battery positive and plate ground)
- I checked the ground at the negative coil terminal (only showed 11.6 volts between battery positive and coil negative for some reason)
- The Pertronix 2001 relay unit is grounded directly to the battery negative terminal and not the chassis - not sure if that matters or not, I have read some conflicting posts regarding the correct way to ground something like this relay
- I have not tested for spark at the plugs yet
Thanks everyone
