well i think i found my problem, going back through my paper work the part numbers dont match up for the automatic. so they sent me a mt one ! i guess i'll try to take it off and send it back.Its not meshing w/flywheel correctly. You may have to slot the top OR the bottom hole to move it in/out.
well i looked up the part # ans they have a listing for a auto and mt ? i think the mt one is clocked to close to the flywheel and the auto one may clear fine ! if i can get the auto nose at the parts store i may try that !Is it a ford pmgr? If it is then it has a factory 10 tooth drive . I rebuilt hundreds of the ford gear reductions at work and never came across a differant depth nose housing. What i have found is if it bolts up then they are going to be pretty much all the same. Talked to a relative thats been doing rebuilds{electical auto} like i did then since they first came out with the pmgf Ford one and said the same thing and he seen alot more then me. For some reason more then the old style starter the clearance drive to flywheel get moved out and is very noisy on about half i have seen. If it still does it with new the best way to add clearance is to add a 12 tooth drive. It meshes the same and takes out alot of clearance from gear being bigger and deeper. I even have used some 13 tooth drive on mustang 2s small flywheels. This way the starter is located by the plate and wont move around on you like slotting the mounting holes. Any automotive electrical place should have a drive in stock for abour $15 dollars... ED
whats the best way to wire it, i had to do this on my last 302 car but i have forgot what i did. when i got it it would stay engaged for a few seconds after starting !The housings on the automatic and the stick starters are different. the nose is offset about 10 degrees. i have run into this houndreds of times. i am a current rebuilder. also if it is not wired thr right way it will stay engaged for a few seconds after the motor starts and will tear up the starter.
so it wires up like a chevy ! send to [email protected] Thanks !The centerline of the shaft is off set you cant really tell by looking at it.
to properly wire it up you take the battery cable from the solinoid on the firewall to the starter and switch sides so that the battery cable is hot all the time. then the stud that the cable originally came off gets a wire from there down to the little terminal of the new stater.
if you want i can e-mail you a diagram to help out. my e-mail is [email protected]
