Hello again. I found a set of D0VE heads for $500 to increase my compression ratio so I can use the cam I bought. My current heads are C8VE. That 8 looks like a 3 but I confirmed it was an 8. The heads I found online could be damaged and is 2 hours away so would it be better to replace my pistons to gain compression Or go with the D0VE heads? I could have the valves replaced and a valve job for about $300 plus parts. I don’t have the $ to put adjustable rockers unless it’s absolutely necessary. I’m not looking for outrageous HP. It seems the more I read and advise I receive the more confused I get. What piston would best fit my build? Would I need to have the cylinders bored? I’ll put a Link to the piston set I have my eye on and the cam kit I already have. Also a pic of the head. I’m 50 years old and this will be my first engine rebuild. I want to do it right but don’t want to bust the bank while doing it. I bought a Weiand Stealth intake, Holley 750 DP, headers with c6 trans and will be getting A 2500 stall converter. Again, any and all advise is appreciated!
