1 - 14 of 14 Posts
TOP END Package: Trick Flow street heads, Never used. Ported, intake and exhaust, all Manley valves, Comp springs and hardware, comp push rods, Roller rockers, Tall valve covers, with studs, Victor 460 intake ported and powder coated black, 1050 Dominator used with all new gaskets. $3k + shipping or pick up is always free!
Short Block: 466ci, factory crank, Scat H-Beam rods, Arp bolts, Arp Main studs, Milidon Windage tray, Speed Pro forged Dome Pistons(full floating) Comp cam is a custom grind solid, with matching solid lifters, 666 lift area will find cam card. Double roller timing chain set, timing cover is also poweder coated, Block is decked, everything is fresh from the macine shop never been fired. 14:1 comp with 74cc heads $3k +shipping
JW ultra bell bbf to powerglide, with crank adapter and JW Wheel for this set up $300 + shipping
Fox Swap: Swap headers for fox, Belive they are d&d 2" primarys with 3" collector used but in good shape, Front Motor Plate used, and Brand new Compitation enginering Mid plate. Moroso Fox swap pan used but hardly at all. New oil pump and pick up to go with the pan $750 shipped
1989 Mustang Drag car street legal with a clean title: 12pt cage through fire wall, welds all around 15x3 and 15x8's lake wood 90/10 struts, eibach drag springs, 50/50 shocks, 8.8 rearend with 4:10 gears, fire wall built in the back. 10 gallon fuel cell installed. battery in the rear with cut off switch installed, 6 switch painless box roll bar mount installed. 1 summit seat drivers side installed. new manual brake conversion not yet installed also new line lock not yet installed, Lakewood lower control arms and upr double adjustable upper control arms with the car also just not installed ( still has the lakewood uppers in the car) Msd 6a box and msd 3 stage retard installed in the car, 5" monstor tach also instlled in the car. $3200 pick up or find shipping, i can deliver part way. call 585-755-3307 or PM or email
will sell motor complete for $5,700+shipping
JW bell, wheel, and adapters,bbf to PG $300+ shipping
Car $3,000 pick up or find a carrier
1 - 14 of 14 Posts
