I have a 460 .030 over using JE flat tops on stock truck rods. D20E-AB heads cut to 85cc and lots of work done to the exhaust ports. Larger valves have also been added to the heads. The motor will be going into my 85 Mustang coupe which is used mostly at the strip. My transmission is a totally beefed up C/4 and a TCI 3500 Super streetfighter converter. I would like to run 9.80-10.0 on the motor only. Can anyone suggest a cam that will get me there? Can this be done without going to a roller cam? Any other suggestions? Also trying to keep this a Budget Motor. Thanks for any suggestions you may have.
