1 - 3 of 3 Posts
I need valuable input for a new combination, to include the right gear ratio.
Combo
A 460 Block w/ 572 kit 14.5 comp
TFS A-Heads w/ 2.350 valves
TFS Ported Intake w/ 1150 annular race carb
Custome Solid Roller Camshaft
ALL INTERNAL BALANCED
Dynamic C-4 Trans w/ 4500 stall
NOS Plate 300hp
Beefed-Up Rearend w/ 3.55 cogs
BF Drag radials 325/50/15 on 15x12" Draglites
YOUR OPINION COUNTS!!!!!!!!
Discussion Starter #2
Help
I know we have some engine gooroos out their. Is this a strong build, for a 8.20 pass or should I go a differnt route. Thanx.........
it looks like its shaping up to be a strong combo,but i think the people on this board might be thinking that not enough info is given. What are the cam specs?how was it installed? (advanced,retarded?) where does power peak (RPM) ? what sized tires? What kind of car? Race weight? things like that. Gear ratio will most likely be dependent on what the HP and Weight and RPM the vehicle will acheive.
1 - 3 of 3 Posts
