Nitrous Express Gemini Stg 6 Dominator 50-300hp (4500 Flange) Kit, part # 60070, Purge Kit part # 15600, Pressure Gauge Flo-Through Kit part # 15509. Switched over to a Direct-Port set-up,...and I no longer have a use for this.
This is complete. Just add your Bottle,.....and you're ready to go. The whole kit has been gone through with a fine tooth comb and comes with a lot of extra fittings, adapters, Cut-Off Valve,as well as extra Jets. This will allow you to customize it, how ever you like. Many of the components are new,......like the Micro-Switch, Relay & Harness, Purge & Activation Switches, and Pressure Gauge
$475 shipped (Cont 48)
606-477-7327
[email protected]
https://www.nitrousexpress.com/60070-10-dominator-gemini-twin-stage-6-50-100-150-200-250-300hp-with-10lb-bottle.html?fbclid=IwAR39bvvBqpJCwlpvDMEllxFFlKFcymDLKkGGLuzvT3REVL_Hl5X-gqKrEaE
https://www.nitrousexpress.com/15600-nitrous-purge-system-w-d-4-manifold.html?fbclid=IwAR3UrmzJlEUhpUxhNiBcTRMGe7xz4Tw3lnmLljkRiuIRxiS7jeIHeuJTKb4
https://www.nitrousexpress.com/15509-n2o-flo-thru-pressure-gauge-0-1500-psi-d-4.html?fbclid=IwAR0D6nsxh4_snqMl48Hm3waL0rowjH6f0xFm__-8sVH2kcHwdbM3qQ9rJIc
