Hello, I need alittle help building a nitrous system.
The vehicle is a f100 3600lbs
460 stock bottom end with 10/1 compression and a mild cam
91 octane
I was thinking about a 100 to 150 shot for when I'm at the track.
With my other trucks (fuel injeted modular)I have always used a wet system with a stand alone fuel system filled with 104 octane. Will this same type of system be the thing to use? Or is it overkill? Will I have to retard the timing?
sounds like your using a carb and plate system. thats what i do have a stock bottom with kb hyper pistons. my system has a seperate fuel pump for nitrous a holley blue. this is the tune i use 50hp 42n 36f jetting 5.5 psi fp 30 * total timing 125hp 65n 52f 5.5psi fp 28* total timing
