Whats the Max amount of Nitrous I can use on this set up? A-heads
2 1050' on a Holmes style intake A-460 block diamond pistons flat tops CR 14 to 1CR 6.800 oliver rods the Max ones.Crower forged crank. Camshaft is 865-830 280-296 @50 114. This is gonna be use in a 1/4 mile drag car @ 2670lbs.It has a 1.76 glideith a 4.56 gear and 33" tall tire.Whats you guy opnion on he build and how uch NOS can I use? Thanks
I would say 'quite a bit'. You have strong parts, but its things like ring gap and sealing force that will determine the threshold of living, and destruction!!
Are you using the 18 bolt heads?? Are your block and heads O-ringed??
I dont have as good of a crank and rods as you do and I spray 500 on my 605BBF start off at 200 and work your way up also depends on what nitrous system I have a dual fogger IS system
you need to get those 1.76 gears out of there! put so 1.80 gears in its place! cam could use a degree or tow on the lsa but try it first and see how it works out with that cam! diffently those gears have to go!
