1 - 3 of 3 Posts
Whats the Max amount of Nitrous I can use on this set up? A-heads
2 1050' on a Holmes style intake A-460 block diamond pistons flat tops CR 14 to 1CR 6.800 oliver rods the Max ones.Crower forged crank. Camshaft is 865-830 280-296 @50 114. This is gonna be use in a 1/4 mile drag car @ 2670lbs.It has a 1.76 glide with a 4.56 gear and 33" tall tire.Whats you guy opnion on he build and how much NOS can I use? What type of HP numbers would you give it on motor? Thanks
You have alot of compression @14.1 for nitrous and the cam is a little late on EVO.... but it should stand 300-400 depending on how good your tune up is and what fuel you run.
Alot also depends on how much quench distance the engine has, ring type and gap, and if the heads are the old SVO bathtub chamber or the newer double quench pad fast burn chamber.
I take it your going to run a fogger? 28-35 jet?
I would recomend VP NO2, C23 or Sunnoco MAXNOS for fuel.
Make sure you have a dedicated Holley 803 fuel pressure regultor for the nitrous fuel side, so you can set your flowing fuel pressure.
Plugs should be NGK -10's.
On 300ish (28 jet) I'd start with 18* total timing.
That motor should make 950-1,000hp on motor if the cyl heads are any good.
Will
in EZ Street 14:1 CR with a 500 shot was the norm. slightest screwup on the tune meant white smoke at 1000 ft. Nitrous is an art, the tune done by the artist. PM me and I can put you in touch with an excellent nitrous tuner. You will need a different cam though. Lobe separation is not fit for the job.
1 - 3 of 3 Posts
