1 - 13 of 13 Posts
63 1/2 Galaxie , .30 over 429 ,mild speed pro cam, Wiend Stealth alum intake ,Summit 650 carb , Griffen two row 1 1/4 " tube radiator ,Hurricane 3500 cfm fan (pusher), High torque mini starter,battery relocated to trunk via welding cable with brass ends , grounded to frame at battery , body to frame, engine to frame with same welding cables.Classic Auto Air HVAC system ,160 deg high flow thermostat ,flocooler water pump.
Now for my problem , I have had heating issues ever since I built this car. It does fairly well (180)on road . Volt meter drops to 12 v when fan kicks on and when A/C is on gets a little under 12.I have two relays for fan ,one turns fan on at 185 deg and other turns fan on when A/C is on. Just a little stop and go traffic and temp will get over 200fairly qiuck. I have tried three radiators on this thing and just put the high dollar Griffen on yesterday. the problem is some what less but still a little warmer than I would like. Can't stay in slow traffic very long at all and that is where you are on some of the larger cruise events. Sure is taking some of the enjoyment out of this car. Any Ideas?
I think the pusher fan is likely the issue. Ideally you want a puller set up with a shroud so that the entire surface area of the radiator sees air flow at idle. Do a search. There are some recent threads on this issue.
I would agree with Tommy. Try switching the fan to a puller if you have the room and see if it helps. Pullers have like a 30% more effectiveness (somewhere around that number) than pushers. Also may think about dimensions (bigger radiator) and a three row.
Thanks guys , Dont have room for a puller my Griffin Radiator is huge and i only have about two inches between waterpump and core . Had a three row champion but tubes were only 1/2” where the Griffin has 1 1/4 “ tubes. Put a 160 deg thermostat and reset timing and car is much better . Let it run in shop for 45 min and fan would cycle on and off and hold temp at 180 deg . Looks like i may have it . Drove it through downtown Paducah , Ky and forgot about quilters convention and it done fine in stop and go traffic .
Racecat do you have an expansion tank above the intake similar to the FE engined Galaxies?The radiator placement in the 60-64 Galaxie is pretty low & sometimes allows the intake or the upper rad hose to be the high spot in the system which prevents all air to be vented from the system.This is a very common problem shared with AC Cobra kit cars (and originals).The Galaxies and Cobras originally had the expansion tanks for this reason (the Cobra used one that did not mount directly to the intake in place of the thermostat housing).A tee in the upper hose with a fill cap is usually not sufficient.An air/vapor bubble collects in the high spot and disrupts coolant flow at low rpm.Smallblock 260/289 Galaxies didn't have it since the lower height of the engine usually kept the high spot at the radiator.
Super Moderator
I agree with the other guys. You need a puller fan setup. It is also crucial to make sure the fan and or fan shroud is right up against the radiator with no gaps so the air can't get around the shroud edge without going through the radiator.
Also what brand of electric fan do you have? Some of the fan manufacturers inflate the CFM ratings in my opinion. So it might claim to be 3500 CFM but in reality it may not even be close to that.
I have two Spal pusher fans (1100cfm each) with a smaller Griffin radiator and have no major overheating issues in my 63.5 Galaxie
I currently have a 550hp FE in the car but previously had a 400hp 429 in there.
Getting air out from under the hood seems more of an issue than getting it IN on these cars. Given enough time idling in the Georgia summer the car will get up to 200, maybe even 210 but this isn't overheating, it's just a high powered car getting stuck at the railroad tracks for 10 minutes :p
I also run 2x4 carburetors, so boiling fuel would be more of an issue with my setup than with most.
I suspect a teardrop hood would solve all of these problems, but I like my stock hood.
I can relate to not having enough room to install puller fans, there just isn't much.
Given your oversized cooling system for the engine in question, I would seriously go over your carburetor tune, fuel quality, and distributor curve.
You and I have very similar projects. I too had a lot of cooling issues at first. I have a slightly larger push fan in front and a 18” Flexi HD fan with shroud. The biggest improvements came after the shroud and getting the distance the fan from the radiator or depth of fan into the shroud correct. My fan blades are less than a half inch from the pulleys. My electric fan rarely comes on even in the hottest weather and sitting in traffic for extended periods.
Fan
What kinnd of shroud did you use ? I have a 18” flex fan on the wall all I need to do is find correct spacer and shroud!
Drove it to a cruise in / fish fry Tuesday night, air temp 97 deg with heat index of 115 deg , car ran 180 with air on max maybe got up to 190 at lights but otherwise done great . But just for curiousity may try adding fan and shroud. Thanks for all the replies!
Got the fiberglass shroud from Crites Performance back in 1994 or so, I went to their website last night and could not find it, but they listed a all aluminum unit that may work. In the time leading up to this I tried a few different pulley fans, electric fans and a variety of thermostats but could not keep it cool. I was looking for a shroud but could not find one I thought would work, until I came across this one. The Flexalit HD 18" pulley driven fan was installed into the shroud about 1/2 the depth of the fan blades and about an inch, but way less than 2" from the radiator. The determining factor was the fan blades were hitting the single groove pulleys so i added the thinnest spacer I could find, I still ended up shaving it down to about 1/4 inch thick to get the clearance good. This is where I turned the corner in getting the car to stay cool. Next I installed a Spal 2360 CFM electric fan in front of the radiator, had to trim a little off the hood latch mechanism to clear and set it to come on at 195 and off at 175. I am also using a high flow 180 degree thermostat.
This setup has worked for me for many years without fail. The other day I was out and got caught up in some construction traffic in 90 plus degree weather, I ended up sitting and barely creeping for at least 20 minutes the electric fan cycled a few times but there was never any danger of over heating. Good luck!
Discussion Starter #12
Been a while since I visited here so here is my update , I pulled the heads and sure enough the drivers side head gasket was backwards so put on new gaskets (the correct way) , a new valley pan intake gasket , trying to help keep heat from bottom of intake . put my 750 cfm carb back on (showed lean on plugs ) to richen it up .I'm using my two row Griffen Rad with 1.5 inch tubes with an aluminum shroud and two 10 inch puller fans , put in a new high flo 180 degree thermostat.
Drove car for about two hours , some interstate at 80mph with a/c on ,some city stop and go about a hour riding around Paducah , Ky in late Sept 85 t0 90 degree outside temp . Car ran right on 180 deg on interstate ,climbed
to 185 in city stop and go driving , after for about 10-15 minutes idling fans came on at 187 deg and kicked off at about 175 deg .As Andy Griffith used to say "I believe we got er if she don't jump".
Thanks for all the help on here I would have never figured it out on my own , I was about ready to pull my big block and go to a 351 !!
1 - 13 of 13 Posts
