Head unit and mounting bracket only! No belt, crank pulley or oil lines. Bracket is for a MOD Motor. Will work of SBF with correct mounting brackets from Paxton.
$1000 BO or trade for BBF parts.
The discharge cover is wrong for a SBF. Mod motors the inlet faces the front of the car the same as the Vortechs right?
Not so on a SBF.
Negative. Call Paxton (like I did) with the serial number and they will confirm that this will work with both the 2 valve mod motor as well as a push rod motor.
