When I drained my oil last, I let it set in the pan and then looked at it. There were an amount of copper flakes in it, so I used a small magnet and it attracted enough metal to make the size of a bb. No slivers, just dust or very tiny flakes.
I then cut open the oil filter, and it had trapped about the same amount of stuff. The metal the magnet picked up was very fine and flaky. The few larger copper flakes were no larger than half the size of a pin head, most much smaller, but a lot of them.
Cam has been fine, motor is running fine, but i will say that when I assemble this motor, getting the cam into it was hard, and then it did not turn real freely. Oh yeah, oil pressure is good, between 25-30 when idling and about 55-60 from 2500 RPM on up with Melling HV pump. No knocks or pings when running or idling right now.
I would be interested in knowing what to look at. The parts the magnet picked up somehow worries me more than the copper.
What do i look at first....and how much trouble am I in for?....this engine has only 2,500 miles on it since total rebuild. Should I just run it and monitor this?
