Update.
Installed a combination vacuum gauge / fuel pressure gauge in place of the PCV valve. With the oil fill tube taped off and the tube that goes to the air cleaner taped off the gauge read zero. Made no difference if the engine was under load or revved up. Thought I would see some needle movement, of course I have never done this before.
Performed a leak down test and cranking compression test on 7 cylinders, did not do #5 due to difficulty of getting access. The leak down test indicated issues, only one of the cylinders that I performed leaked air into the crankcase, the others were valve leakage which is a disappointment since the heads were rebuilt. I performed the compression test and leak down tests several times to confirm the numbers.
#1 - 22% leakage, 135 PSI compression
#2 - 7% leakage, 145 PSI compression
#3 - 22% leakage, 145 PSI compression
#4 - 22% leakage, 150 PSI compression
#5 - did not do
#6 - 22% leakage, 150 PSI compression
#7 - 2% leakage, 150 PSI compression
#8 - 7% leakage, 150 PSI compression
