I am looking for suggestions on a good oil filter adapter for my 460. I will be plumbing in an oil cooler thermostat and a nice oil cooler I got off of an airplane.
www.cantonracingproducts.com
The oil cooler has -8 fittings and the thermostat from canton can take up to -12 fittings but currently has -8 in it from the previous car I used it in.
Obviously I want an adapter that does not impede oil flow. I would like one that lets the filter screws right onto the block adapter but if I need I can use a remote adapter.
Anyone have any suggestions for a good adapter for my use? This is going in a 71 f350.
22-480 Thermostat For Oil Cooler Black and Clear Anodized
Our Oil Cooler Thermostat helps your engines oil come up to temperature quickly and holds it at the right temperature. Cold oil does not flow and does not lubricate correctly. Plus, moving cold oil robs power. This thermostat is designed to bypass the cooler until the oil reaches 215 degrees. At...
