1 - 3 of 3 Posts
My #5 tube is blocking my oil filter, maybe able to go with the shorter 3000 filter, but still close to that heat source.
What would be better, short filter, 90 deg adapter, or remote? Its going in a 67 Mustang with front plate, long tubes.
The short filter and the 90 degree would probably be more reliable than the remote; but the remote gets the filter away from the heat even though the hoses are still relatively close. Whichever you decide on perhaps you should add a heat shield.
Napa 1335 super short filter
Attributes
Filter O.D. (Inches) : 3.67"
Height (Inches) : 2.483"
Thread Size (Inches) : 3/4-16
Beta Ratio : 2/20=6/20
Burst Pressure : 280 psi
Filter O.D. (mm) : 93 mm
Flow Rate : 7 - 9 gpm
Gasket I.D. (Inches) : 2.462"
Gasket I.D. (mm) : 63 mm
Gasket O.D. (Inches) : 2.834"
Gasket O.D. (mm) : 72 mm
Height (mm) : 63 mm
Media Type : Glass Enhanced Cellulose
Micron Rating : 21 Micron
Style : Spin-on Oil Filter
napa 1515 specs standard ford filter
Attributes
Filter O.D. (Inches) : 3.66"
Height (Inches) : 5.178"
Burst Pressure : 290 psi
Gasket I.D. (mm) : 62 mm
Height (mm) : 131 mm
1 - 3 of 3 Posts
