Hello all. I have a Ford 460 rebuilt it a year or two ago and never ran it for more than a min or two till today. Got oil pressure and sounds ok. Then I look under the truck there a good size puddle of oil. Coming between the trans and engine. I know it’s only a couple of things that can do this.
The bolt on the driver side trans on top.
The oil pressure sending unit
The rear Main seal.
I I know it’s not the oil pressure sending unit the bell housing and back of block are clean.
the bolt for the the the trans has a little oil on it but I don’t think nearly enough to cause the puddle.
I’m just curious if you all have any other thoughts. I will attach photos
The rear Main seal.
