Ok guys, I searched before posting, found some things, but still came up short!! I am having issues with the rear main seal on my 521. I am running a 70' 460 block, Scatt crank, and all the goodies to go with it. I cannot get the rear main seal to NOT leak/pour oil out of it. It has to be the seal because the 2 oil galley plugs and the cam plug are sealed up tight with no signs of oil leaking. The block and rear cap have been checked by two different machine shops, the crank has been sent back to Scatt and checked out to be true and correct, no knurling/smooth. I am running a PCV system on the RH valve cover and an open breather on the LH valve cover so I should not be building any pressures. And yes, I am installing the seal correctly and dabbing a small amount of silicon where needed!! The oil pan is tightly sealed in the rear as well. Can you run a rope seal with the Scatt cranks??? I am totally out of things to try and looking for different opinions. If someone could shoot some my way, I would be very thankful and excited to try them!!
One thing I have to ask. I was asked what oil pressure I am running. I told that individual that it was around 65 to 70 running 3K RPM down the highway. He thought that I was running way to much pressure and that it was blowing passed the seal. I have to beg the differ, but thought that I would throw it out in the open!! Have a great evening and I hope to hear something back soon!! Thanks again!!
Waycooljr
Waycooljr
