I am sending my block to the machine shop next week, was wondering do I need any kind of oil mod? I have read different post on this and it appears under 1,000 hp it's not a have to kind of thing. I do plan to run a Kaase oil pump and a 7 qt moroso pan. also keeping the RPM's at around 6800.
Go to Paul Kane's site and read his block mods, maybe not necessary but for what little it takes to do them it can't hurt.
With what little info you've provided about your build I would suggest you massage the oil passages as outlined in the Technical Pages of our website...assuming you are using a passenger car block.
I understand the dist. oil mode. I also understand opening up the oil pump surface to 9/16 from 1/2 but if I open up the oil pump surface do I have to open up the oil filter opening or can this be over looked?
