WE got in three passes yesterday( 1 /8 mile) on our new setup, very dissapointing!! We still have time to tune but Im going to need you help. The car A 3400 # 64 fairlane,tubbed and caged with stock suspension and lakewood J traction bars and a nine inch slick 28 tall ! I has 430 gears in a 9 inch. The motor is a 468 with speed pro hypers(flat top)comp cam 282s solid cam,eldebrock rpm heads 75 cc . 5 in the hole for deck,eldebrock rpm intake, windage trays, moroso 8 qt pan,comp rockers, 2 " primary crites headers and an unopened box stock holley 750 dp , 30 degrees timing . The car lauched good with 1.80 60 foot times but just didnt pull that hard. I lauched at 2100 the first pass(3000 stall) 8.43 /79 hitting the 6200 chip once, the second pass I was way better because I was less nervous 8.34/82 The third pass I lauched at 2800 It ran an 8.11 at 83 ! much better but not!! It was 95 with a 18 mph wind the car wanted to heat up fast (220 by the time I got hurried back to the trailer)We have an afco 19 x 26 radiater in it, biggest restricter ,procomp electric water pump,17 in pusher with the curved blades,It cooled down fast in the pit but I know it wont take this very long! I have acsess top an 850 racing carb, I will post the # later! Will a bigger carb take care of my heating problems? I can see if I can get a bigger fan on it maybe. I think 370 gears would also let the motor torque instead , I would much rather limit rpm to 5500 or so. I shifted at 6, 6 and just got into 3rd 60 feet from the end of the 1/8 so I know I wont work as is for topeka!! I have any gear available so suggestions are valued, what jets and timing should we be running! Please any suggestions are valued Thanks Dave
