Billet Double Roller T-Chain Sets, and a Warning
I carry the .005 under size Rollmaster Billet 9 pisition indexable chains in stock. These are the absolute best timing sets on the market, and cheaper than the equivalent Cloyes by quite a bit. The Rollmasters use the premium German made JWIS chains, and both gears are billet steel. If you still need one, let me know and we'll help you out.
While I'm on the subject.......
One really needs to check their timing chains closely on installation. We just had a customer bring us a Comp Cams billet chain for his 520 build. Real nice looking, made by S-A Gear. But, it comes with a note in the package that mentions that you might have to machine the nose on the cam as they did not make the cam gear with the proper depth to get the correct cam thrust. Sure enough, it was wrong, and the chain had way too much thrust. We then checked for runout, and it was significant. We didn't even have to measure it. As we turned the engine over, the chain went from tight to loose. The cam gear was machined off center and was acting like an eccentric. We've seen this quite often with the S-A Gear sets that everyone is selling, and a number of times with the Cloyes. That chain went back in the box, and we installed a Rollmaster. These examples are all with upper grade .250" roller chain sets. I don't typically work with the budget level chain sets. Also, the cheaper the chain set, the smaller the roller pin used. Double Roller chain sets are available with roller pin sizes of .180", .200" .220" and .250". That's why a Cheby guy can buy a "Double Roller Timing Set" for $15!
The other area to be aware of is that the chain could actually throw the cam timing off. I've had both the S-A and Cloyes come up off when we degree the cam. We put a Rollmaster on for comparison, and the timing comes back to normal. One S-A Gear set put the cam timing 12* off on a 460 build. Good thing we checked it and it wasn't the customer just installing it dot to dot! With all the problems we've had over the years with chains, I try to move our customers into a Rollmaster Timing set on EVERY build. So far, knock on the old wood, with well over 500 Rollmaster Timing sets sold & installed, we have yet to have a problem with one. (Besides being tight on the crank snout-they are all sized small and will be tight on Scat/aftermarket cranks.)
Besides not fitting correctly, excessive stretching in use, and improperly indexed cam timing, we've heard of quite a number of actual timing chain failures on the dyno, when using one aftermarket billet chain in particular. Like every other component you choose, it pays to investigate. And just because it comes from a "name brand" doesn't make it good.
Rob McQuarie
Blue Oval Performance
303-762-8298
