1 - 3 of 3 Posts
Well I got one more cam laying here. This one came in the Ford Racing 514 crate motor I bought, I don't have the sheet but could be found. I think .647 lift somewhat mild duration but has a good sound. $150 plus shipping , Pat
OK found it;
514 Cu.In. Crate Motor - "600 HP" Bracket Race PART NUMBER: M-6007-B514
600 horsepower @ 6250 RPM. 590 ft./lbs. of torque @ 4750 RPM. 9.8:1 compression ratio (Nominal). Sturdy 460 2-bolt main short block M-6009-B514. Cast nodular iron 4.300 inch stroker crank. M-6200-A514 connecting rods with ARP bolts, AMPCO 18 rod bushing. Ford Racing/TRW forged aluminum dished pistons with full floating pins. Mechanical roller lifter camshaft with .647 inch lift, 254 degrees intake and 258 degrees exhaust duration @ .050 inch lobe lift. M-6049-C429 "Cobra Jet" aluminum cylinder heads. M-9424-H429 "Victor Jr." single plane intake manifold (requires Dominator carb). 1.73:1
Pat,
I'll take it if it's not too late.
SJ
used 2b RHP
:D
1 - 3 of 3 Posts
