Well we finally got the Mercruiser 4 cylinder motor in the car and running. The owner of the car let me drive it at the track for its debut and I have to say that it is one bad 4 cylinder. We had some bad luck with the motor but hopefully it didn't hurt anything. The cam pin broke in the motor.
Here are some specs. 4.390 bore Diamond pistons, offset ground 4.050 stroke stock crank, 6.800 GRP aluminum rods, reground flat tappet camshaft, Ford Motorsport Super Cobra Jet head, 4 barrel intake, and a 740 cfm alcohol carb. Our intentions are to turn it around 6500. The car is an open wheel modified with a bert transmission and weighs around 2300 lbs. I don't have much circle track experience but when I made a few good laps it would pack the left front wheel all the way down the straight. I honestly think it will be competitive in the V8 class when everything gets straightened out with the motor and the car.
The class is called Outlaw 4 cylinder. The only rules are 2000 lbs with a naturally aspirated 4 cylinder motor. The biggest competition are all aluminum Esslinger engines. I think it should have no problem competing when everything gets lined out.
