1 - 3 of 3 Posts
Situation
My 172K mile 6.0 tow/haul light flashes whenever I put it in tow/haul mode. Doesn't seem to apply engine braking at the lower speeds or hit 1-2 like it used to. When not in tow/haul mode the light does not flash even when pulling about 10K lbs. As sometimes takes a long time (15 count) to go i reverse Codes are P0730 and P2700. Trans serviced every 50K miles and pulled a 10Klbs trailer about 50% of its life
Questions for the all-knowning group?
1) Time for replacement before it leaves me stranded and count myself lucky I got 172K.
2) Is a Ford replacement 3yr/unlimited mileage warranty the way to go.
5r110 does not use a valvebody, rather a bunch a pressure control solenoids.
The P0730 is a gear ratio error code, the P2700 is related to the coast clutch.
Your gonna go into the unit, unless you can find a shop that is familiar with that tranny I'd stick a Ford reman in it. The reman carries a very good nationwide warranty.
1 - 3 of 3 Posts
