timing and fuel mixture can turn the manifold to hot , both together is a guarantee . timing can be set (close) if you know the dist. curve . over advance is not so much an issue when there is no load on the engine .
This is usually the culprit ... use a vaccuum advance or advance the timing much more than you have it.Timing retarded.
Put money on it.
