1 - 13 of 13 Posts
-P51 heads
-Stock 460 block .080 over
-Scat 4.5" crank
-Scat h beam rods
-Probe flat top piston
-Solid roller cam, .824,.786 290/ 299 @ .050" 110c
-CAT rockers
-Comp roller lifters
-14to1 cr
-Victor intake w/spacer
-Canton oil pan
-MSD distributor and crank trigger
more to come....
pictures,dyno numbers,etc...
yea i will be spraying it(between 150-250 depending on what i need at that moment)but not all the time only when needed.
its goin in a 84 notchback. ill try to get some pics of the engine and car on here soon
ill get them on as soon as possible, may be a couple of months or so. had to put my project aside so i can get all customers ready for the season.
Looks decent
Should be intresting. IMO I'd be nervous with CAT rocker arms using a roller that big. The rpm range and the amount of spring pressure involved... Keep us posted.
thats true. thats why i test "free stuff" on my engine before consider using them on customers engines. if it breaks i can only blame myself :) ill keep posting as i go.
can somebody tell me how i can get pictures on here?
Discussion Starter #12
thanks richter69, ill try to get some pics on.
69ratrap, thats a good train of thought. they are the steel body rockers, so ill test them and if they dont work ill scrap em. and ill keep a look out for the shafts.
1 - 13 of 13 Posts
