1 - 13 of 13 Posts
Clearing out my garage and barn. Thought I would give you guys a shot before I deal with the e-bay nonsense.
Prices do not include shipping from West Central Florida.
Holley finned aluminum valve covers 429/460, need to be blasted or cleaned. SOLD
No name or logo finned aluminum valve covers 429/460, blasted and clear painted SOLD
Edelbrock Performer 460, std. ports, very little use. 175.00
Hurst 5384106 chrome shifter handle, includes white Ford Motorsport 5 spd. Ball. New 70.00
SRP 150723 pistons. 429/460 flat tops with wrist pins. New in original box. 400.00
Flaming River steering box 67-69 Mustang 1:16 ratio. New, bolted on car once. SOLD
Crites Gen 1 mounts, 429/460 into 67-69 Mustang. New, in original box. 100.00
Ford Motorsport finned aluminum valve covers 351C. Will need to be cleaned. 100.00
1972 Cleveland factory steel stick bellhousing. Out of 72 cougar 351C/3spd car. Will fit many other years and engines. 75.00
Lakewood Blowproof bellhousing for Small Block ford, diaphragm driver side pivot style, has had some clearancing done around the bottom bolt together flange for header clearance. SOLD
Mallory 3755101 Unilite Distributor for small block ford. Works great, needs cleaning. Includes cap and rotor. 175.00
Edelbrock 1725 high volume fuel pump. Small block ford. New, in original box. 70.00
Sealed power 2600CP10, Federal Mogul 4125 MA10, Sealed Power 1204M- New in original boxes main and rod bearings (.010) and std. cam bearings. 50.00 for all.
Daystar 473577 1 ¾” leveling kit for 2wd 2003 Ford F250. Fits many other trucks as well. New in original box. 75.00
Huge Modine circle track aluminum radiator. Core is 23”x17” and is 5” thick. 100.00
Very rare styled steel wheels off 72 Cougar convert. 14x7 designed to clear factory disks. All four wheels with caps and trim rings (caps and rings are in fair shape) 400.00 for all four.
US Body Source complete 1969 Mustang fiberglass kit. Doors, full length hood, pro stock style scoop, one piece front fenders, valence, grill and both fastback and coupe decklids. Still in out of molds shape. 1500.00 pick up only.
Rear disk parts for Versailles rear end, calipers, brackets rotors etc, both sides. Sold
1967 Fairlane power steering set up, from steering box to idler arm, drag links, control valve and hoses, no tie rods. Except the box, all new, control valve completely rebuilt. Only the rubber boot on the outside of the hydraulic ram needs to be replaced. 400.00
Maverick/Comet factory 302 frame brackets, under engine crossmember and C4 trans mount crossmember. 250.00
Maverick small bumper parts, have the whole front end parts needed to convert, bumper and brackets, fenders, valence, etc. Sheetmetal is in fair to decent condition. All off 72 Maverick. 300.00 pick up only.
Also going to be selling my 1984 Jeep CJ7 with 302/C4 conversion, frame up rebuild 23k miles ago. Hardtop, steel doors, poly lined interior, custom bumpers and rock guards, winch, 33x12.5’s, Warn hub conversion front, Warn full float conversion rear. Woods double cardan driveshaft. 302 has 68 4v heads, forged flat tops +.030, ported, roller rockers and girdles, Cam Research 4wd specific cam. Edelbrock intake and carb. Custom Art Carr 4wd specific converter and valve body, PA servo.
And selling my 1984 Mustang bracket car with 460/C6, back half car, trans brake, 14x32/s, MSD 7, 10.90 car at 2800 lbs, spool 33 spline 9”, Hooker super comps, ported DOVE’s, filled block, Reed roller cam.
Pictures available upon request. My internet connection is too slow to upload a bunch of pics at once.
PM me with any questions offers, I check the site daily.
I have a lot of other boxes to go through so I will post more parts separately as I get through them.
Radiator Pics.
Overall dimensions are 28.5 wide, 17 high, core thickness is 5". (5 tubes wide)
Upper outlet is passenger side and is threaded. Looks like 1 1/4 NPT.
Bottom outlet is 1 3/4 hose on drivers side. Also has a threaded outlet on upper driver side, looks like 3/4 NPT. It weighs 30 lbs.
curious
jsut for sh*ts and giggles, send me some pics and your price on the CJ. My wife had one in college and has always missed it.
Do you have the alternator bracket and power steering pump bracket (that bolts to the water pump and block) for a 70's Ford 460? If so, how much?
1 - 13 of 13 Posts
