motorsport alm. crank spacer new m-6359-c460 $30.00
wilwood porprtioning valve new $25.00
1-set of 8 childs&albert zero gap secondary rings new zg116x4-505
4.505 diam. 1/16 $40.00
autometer #3241 15 psi sender new $5.00
autometer mini shift light used $10.00
eastcoast mini 16v alt. used $35.00
msd plug wire markers #3414 new $4.00
csr bbf water pump plate red $20.00
1pr. mr. gasket ultra seal exhaust gaskets 720-5910 sqr. port 1.85x1.90
$10.00
ATI sbf crank hub adapter #916560 $25.00
1-set misc. comp cams 1.437 valve spring shims $5.00
2 weld wheels center caps install from back of wheels new $10.00
2-weld wheels center caps o-ring push in style new but need rubbed out
(tarnished) $10.00
BBF block casting #dive think its still standard $50.00
Solar battery charger #670 (made in USA) 60 amp 6volt/60/40amp 12volt
30amp 24volt-325/225/235 amp on start $125.00 limited use in 9 yrs.
Thanks Gary
$10.00
(tarnished) $10.00
Thanks Gary
