1 - 11 of 11 Posts
1. Jesel belt drive w/ distributor assembly. Complete kit w/ (2) new extra seals, new extra belt. Distributor comes with bracket, belt and cam drive pulley, Very good condition. $975.00 (sold)
2. Dry sump oil pan, aluminum, for (3) stage pump. Custom made, looks like about 10 qts., includes (3) trap door sections, windage screen. (could easily be made into wet sump or exterior single stage pump pan). Ribbed bottom of pan shows slight damage from track debris. $240.00 (sold)
3. Stock Car Products (3) stage dry sump pump. (2) 1.2 evacuation sections, (1) 1.4 pressure section. Includes pulley. Very good condition. $450.00 (sold)
4. Moroso dry sump tank, 5 qts. , removable top, mounting bracket, very good condition (no dents). $250.00 (sold)
5. (2) Moroso breather units with filters, aluminum, 7" x 3" $60.00 ea. or both for $110.00 (sold)
(6. Moroso vacuum pump, includes mounting bracket, regulator, (1) gilmer belt pulley. (1) small "v" belt pulley. Good shape. $325.00 (sold)
7. CSR water pump, blue anodize, (no pump plate). Very good shape. $200.00 (sold)
8. MSD crank trigger assembly, Small block Ford unit. Good shape. $130.00 (sold)
9. Tilton starter, severe duty unit. Very good condition. (has been clearanced on the mounting plate for pan and 164 tooth flywheel). $225.00
10. Comp Cam. (new) duration 289 in. lobe lift .485 intake , duration 292 ex. lobe lift .500 exhaust , 114 lobe seperation. $230.00
11. Bullet cam ( I think), (new) duration 286 in. lobe lift .470 intake, duration 303 ex. lobe lift .517 exhaust, 115 lobe seperation . $230.00
12. Bill Miller rods, set of 8, 426 forgings, 6.800 long, .990 pin, BBC rod end, on center(no offset). 100 easy passes.$200.00
All parts are + shipping. For more info. call Joe Sr. at 707-864-0332
I can e-mail pics. to those interested Note; all parts are for a BBF except crank trigger.
I am using A441 heads w/ 1.75 int. rockers, and 1.60 ex. rockers. Using 2" dia ex. valves, on an experimental basis w/ a lot of NOS. Just to see if a lot of exhaust duration is really necessary w/ NOS.
Bump for a good seller! :) I got the drysump parts today and all looked better than expected,some parts look like new! If i needed a belt drive i'd be all over it! Thanks Joe! :D
Thanks for the Crank Trigger Joe. Item was in great condition and shipping was prompt.I looked for a way to leave a positive feedBack or something, didnt see anything, so figured this might do.Best of luck.
1 - 11 of 11 Posts
