1 - 10 of 10 Posts
I'm guessing it's the same one summit carries? Could you post a link?
Just curious, why aren't you using it, and does it have the instructions and assembly lube with it?
Shipping estimate to Baton Rouge, La 70808 would be great?
Thanks a lot,
-Matt
Thanks a lot,
-Matt
i just installed this kit. it comes with lube and instructions, albeit vague instructions. hopefully seller still has them. just a heads up and free bump
they are hydraulic flat tappet
Performer-Plus: Designed for optimum torque from the low-end to the mid-range, camshafts match with Performer manifolds for vehicles operating from off-idle to 5500 rpm. They are smooth idling cams for daily driving.
#2167
ENGINE: FORD 429-460 V8
RPM RANGE: Idle-5500
Duration at 0.006" Lift: Intake: 272° Exhaust: 282°
Duration at 0.050" Lift: Intake: 194° Exhaust: 204°
Lift at Cam: Intake: 0.265" Exhaust: 0.280"
Lift at Valve: Intake: 0.460" Exhaust: 0.480"
Timing at 0.050" lift: Open Close
Intake: 8° ATDC 22° ABDC
Exhaust: 37° BBDC 13° BTDC
Centerlines: Lobe Separation - 110° Intake Centerline - 105°
1 - 10 of 10 Posts
