1 - 9 of 9 Posts
Sweet thanks. Could the pressure port be used for a sending unit for a temperature gauge or would it be better and more accurate to T into the line leaving the transmission?
Not really plug related but is there a difference on internal parts or anything on a 2wd vs 4wd C6. Planning on rebuilding the trans but didn’t get the 4wd kit. Does the 4wd kit just have parts for the transfer case and is there anything I need to be aware of when removing the transfer case from the tail housing?
Not sure exactly what transfer case , you may need a gasket where t/case joins to trans
Internal parts are the same
You may need the correct filter if you have a 4x4 pan , there are 3 different C6 filters , you need the correct one based on what pan you have
1 - 9 of 9 Posts
