I subscribed to Scotts Re-Carnation site months ago and have been through it several times but I am still a little confused. I have D3VE heads and when reading about and looking at the pictures on the modification to the "bump" the pictures AS CAST do not look like mine. In the pictures the bump looks like it is maybe half the height of the valve boss, on my heads they are the entire length of the boss from ceiling to the end. When I started to remove the material, the bump "opened up" in the center due to the hole that runs up through it into the horizontal passage. I have removed all of the "bump material down to what I would consider the valve guide boss and until the horizontal bump was smooth with a small hole in the ceiling. I did not remove the horizontal passage as I have read in earlier posts people have drilled straight through the heads and driven a rod through the head. I did not modify the valve stem boss either. What part of the bump was supposed to end up looking like an air foil? And if I do not modify the valve boss am I leaving a lot on the table? This is for a street driven 4000lb Galaxie looking for 400-450 hp. I have gasket matched the intake already, followed the exhaust port instructions and bowl area below the valves but just do not want to hit water. Can someone please tell me what I am missing here and if there are different styles or am I just not seeing the picutres clearly.
Thank you
Thank you
