On the power steering pump(the one with the plastic reservoir) that would have come on my truck, What size is the pressure out port on it. Need to know so I can order some fittings to do the -an hoses.
I am not sure what year your truck is or if it uses the same pump that I have (which came off an 83 Lincoln) but my pump uses a 3/8" inverted flair fitting on the pressure outlet on the pump.
That looks exactly like the pump I have and on mine. The hose fitting on mine is 3/8" inverted flair. I do not know when Ford went metric so I can't tell you 100% what you have - I just know what I have on mine.
