I am getting ready to fire up my first 460. So far I have primed the oil pump, gotten #1 cyl. on the compression stroke by rotating the crank until the #1 intake valve closes, then continuing to rotate until 12 deg. BTDC shows up on the timing pointer. The truck has an electric fuel pump, so filling the carburetor bowls should not be a problem. When I install the distributor, I plan on pointing the rotor at #1 spark plug wire, then removing the #1 spark plug, grounding it, and turning the distributor until the plug sparks. I figure this will get the timing close enough to start the engine and run at 2000 rpm for the cam break-in. (I have some zddp addative for that) I will do the fine tuning of timing and carb after the cam break-in. Have I missed anything? Does anyone have any other suggestions?
