powerglide 2500hp This tran is just been rebuilt with no passes. It has the following parts
180 str.cuts,New
used 300M output shaft and cage
Nasa promod imput,400 spline, and
Promod pump [5passes on both these]
new 8 clutch high gear, and clutches
new kevlar band
double ring servo
probrake valve body
deep pan
SFI saftey sheild
Dedenbar tailhouse
All rollerised
Available,with BBF ultrabell or Brand X Ulrabell
Note: We build Powerglides, for your needs
JRC Performance
Judd/Rick
lower price,on Promod pg
OK,, guys here is a deal,, We have lowerd the price on this trannny. $2400.
If you look at this trans on anybodys price , you will see $3100. on up to $4000.
You won't find a better deal. Need to move it. YOUR GAIN our Loss
PG
Promod in a stock case ??
Aftermarket tail
Do you have a number I can call you at ??
Dont need Bell, have a turbo spline coan converter, so will input shaft work
Ron
[email protected]
