1 - 20 of 26 Posts
Do we have a PG builders in house that would care to share the secrets of making one live?
I would like to make a PG sticky similar to Frank's build up of the C6!
I'm building one this winter also, seems the secret is high $$$ parts! :) aftermarket case, billet straight cut gearset that's 2k right there!
Unless you have a pro mod you don't need a billet set.
I've run BTE 1.80 straight cuts for years. Never broken one yet.
$750 to your door from my dealer.
Discussion Starter #6 (Edited)
I am gonna need 2 sets David. I have 2 69 Chevelle glides I picked up for a steal I am gonna have the stock bell cut off and use an Ultra-Bell. I did some research and this is my plan of action;
Stock case cut for Ultra-Bell
Machining case for roller bearing on output shaft
Billet roller bearing governor eliminatro kit
1.80 straight cut planetary set
Stock forward drum with new bushing
Billet forward clutch apply piston for 8 Alto Reds
Steel clutch hub for the 8 clutch pack
Higher pressure springs for direct
Billet reverse apply pistons with deep spring pockets for 6 Red Altos
Higher pressure reverse springs
Upgraded reverse spring retainer for the stiffer springs
Kevlar stock width band
High strength band adjusting screw kit
Billet dual ring servo with billet servo cover and high pressure servo spring
Coan High volume pump for TH imput converter
Coan 300M ringless imput shaft with TH splines
Coan Protree 5 transbrake valvebody
I have only a very limited time researching them but seems this combo should be good to ~1200hp in ~3000# vehicle from what I have been told if you can avoid hard tire shake.
I am putting my C6 back together and that will more than likely be the trans that goes into the truck to begin the season but will at some point swap in the glide to see if the truck likes it better or not.
David Cole,
I'm in the market where do I get one ? Thx
Contact Steve Oldani aka transman on several forums. He has a regular job and sells trans and parts as a side biz. Mine has a. JW bell, case and tail but all BTE internals.
The gears are all made in house at BTE. Good stuff
Price is now down to $725 shipped!!!!
http://oldanimotorsports.20megsfree.com/
Or
http://oldanimotorsports.20megsfree.com/custom3.html
His web page
Offers great service after the sale too
Many of us on this board and the other bbf board have bought from him.
You have some good parts listed, but some are really not needed at this level. Too much overkill for anything short of 2K hp. My comments added on each item.
ok
not needed, no faster than a stock bushing, been there done that
not needed
for sure!
will be fine
no need you can machine a stock piston sohe drum will hold 7 thin clutches
a must
no need
no need, you are not doing anything in reverse other than backing up or for the transbrake, if the pump is making proper pressure theT-brake will hold fien at your power level
no need
no need
good
good
good, make sure to get servo that uses metal rings vs rubber o-rings or teflon rings, reason is stock case will often have score marks in the servo bore that will eat rubber or teflon
ok, but take a look at the stock pumps you have. If there is no wear in the pump crescent slap in a new set of pump gears an do the free pump mods described in Carl Munroe's book "Powerglide Handbook". These are the same simple mods done to any rebuilt oe pump from Coan, etc.
Ok, I have a Trans Spec NASA shaft in mine, single ring.
Pick the one of your choice. All oem base cast iron VB's will be really similar. BTE has a new one that I use. It's cast iron, but an all new casting that deletes any unused passages.
A list of what is in mine is in the next post.
A list of the part in my glide. It's a about 1100 hp and makes big torque at 920 ft lbs peak. I have also hit it with a 300 shot on the line. Weighed car 2 weeks ago at Bowling Green. 2955 lbs w driver. 2 years so far and the trans is still perfect. All the parts except the trans case, bell, tail and input shaft (already had) came from Steve Oldani aka transman.
1. 1.80 straight cut planetary.
2. Transbrake, BTE Pro brake. Part # 228260
3. Complete rebuilt kit with thin clutches and Kevlar band. Kit needs all bushings as this is a new build.
4. Dual ring servo, prefer metal rings, Teflon is 2nd choice. No rubber O ring type.
5. Aluminum servo cover.
6. New servo spring
7. clutch hub, steel. used 7 clutches in a stock drum with machined stock piston
all stock reverse piston setup with good clutches
8. aluminum deep pan
9. HD Band adjustment screw
10. 2 pc shift lever and shaft
11. JW Ultra case, bell and tail shaft
12. Trans Specialties NASA input shaft w rings, turbo spline
13. Stock pump with new gears and simple fluid flow mods.
14. TCI locking dipstick
Any other parts are stock
If you have never done one before, get this book, well worth it!
[ame]http://www.amazon.com/Powerglide-Trans-HP1355-Chevrolets-Applications/dp/1557883556[/ame]
Discussion Starter #12
I am making every effort I can to get it to 3050 with me in it for next season. Even at the current weight (300+) Steve Oldani said I would be a good candidate for a glide, and should help being a small tire deal with the starting line. My truck was leaving good but the converter went out and really wonder if it wasn't bad from the beginning and it was under stalled anyways so that may change. I started looking into the glides before I tore my trans down and realized their was nothing wrong with it other than a broken pump gear from chunks of aluminum from the sprag coming apart. So now the converter for the C6 will be getting fixed under warranty so I am gonna put together these glides and will be able to make a mid-season swap to see if it is better or not.
Thanks David! This is turning into quite an informative thread, a few of the parts I was planning on buying new were because the cost new vs. the cost to machine some of the stock parts was so close it seemed to make sense to just buy new. I do have a sponsorship deal with a machine shop for machining trans parts SOOOO I could have them done for free (now that you mentioned it).
Unless your pump is modified, I wouldn't run a ring-less shaft. Stock cases are good up to about 1200hp, maybe higher. Would definitely use a turbo spline input. 1.76 stock gear sets are pretty good on their own for lower weight or powered cars.
That's about the extent of my transmission expertise.
Discussion Starter #14
Thanks guys, I think we have a decent build on a Glide to handle ~1200hp. Seems that it would only take a few mods to build a pro-mod glide from this point one big thing being the case and the other being the rear planetary. I have been told the stock 1.76 planetary is the strongest of the OE ratios and can handle power up to ~850hp.
Definitely see how these can get really expensive though.
So for a sub 550hp mustang about 3350 with me in it, what is a MUST to have?
Trying to decide between a pg or a c4 for a year or so in the future
I had 2 friends both break their PG cases this year at the track, both make around the 800 FWHP mark. But, both breaks were in the bell housing area of a stock GM pattern bell. They have since stepped up to the Reid cases and man, they are NICE! I will be buying one with the BBF bell for mine. Nice to not need a blanket or external shield especially if you have a tight trans tunnel.
If you can swing it the aftermarket cases are very nice.
Stock glide cases seems to be the luck of the draw. I've seen them hold up fine in 1K hp cars and seen them break in 400 hp cars. Variations in the casting thickness. I broke one in my sbf 69 mustang, replaced it and ran the next one for years until I sold the car.
They will break at the bell, but the majority of the time it seems like they break at the rear near where the reverse piston is in the case. Case is thin back there. Some are obviously too thin.
another topic worth looking at is how to mount a glide.with motor plates the trans mount takes all the stress.i use limiters on the block and on the trans where the mount was.i think the trans mount setup can cause a broke bell,IMO.
sbc with solid front and rear mounts , some will break one the first pass . others make it to 3 passes are rare
1 - 20 of 26 Posts
