dive block zero decked for 4.3 stroker
comp custom cam
scorpion rollers
SCJ heads
What length tool do I need to buy?
Discussion Starter · #4 ·
First-If you buy a comp cams push rod checker buy a high tech not a magnum. With the magnum you have to measure but the high tech you can count the turns and do some math. I bought a magnum because that is the kind of lifters that came with my cam, but it was not the best choice for me. I guess I should have read the descriptions very carefully before ordering. Luckly I figured it out before using the high tech method with the magnum and ordered the wrong pushrods.
Second how do these lengths sound? Intake is 8.850 and the part number I am looking at is 7910-1 which is 3/8 hardened. The exhaust looks to be 9.400 which would be part number 7755-1 whis is also 3/8 hardened. Do these sound correct? Is there something else out there I should be looking at?
Again it is a
DIVE block machinest said he decked it 0.005 for 0 deck on stroker assembly
Custom comp hydro cam
Scorpion RR
SCJ aluminum heads
With the Crane/FRPP rockers the FRPP p. rod kit for the SCJs has 8.850" intake and 9.150" exh.
