I just did mine and came up with 8.750. This was with D0VE heads, Ferrea valves (longer stem) and Comp roller tip rockers. First time I have ever done this so I can't offer much more advice.
Best of luck
I just did mine and came up with 8.750. This was with D0VE heads, Ferrea valves (longer stem) and Comp roller tip rockers. First time I have ever done this so I can't offer much more advice.Going to make a pair of pushrod length checking tools... with D0VE heads on a factory block, what is the worst case shortest/longest I need to think about making them fit... maybe 8.4" - 8.9"?
Tom
Yes Tom, 8.4"-8.9" should cover 95% of pushrod lengths used/needed by engine combinations such as yours.Going to make a pair of pushrod length checking tools... with D0VE heads on a factory block, what is the worst case shortest/longest I need to think about making them fit... maybe 8.4" - 8.9"?
Tom
would 9.250 be to big on the roller tip rockers!Yes Tom, 8.4"-8.9" should cover 95% of pushrod lengths used/needed by engine combinations such as yours.
Paul
