1 - 11 of 11 Posts
My front hub on my 4x4 seized can they be rebuilt? I bought a new one but the other side ,i would like replace it to. Any one know if this can be done or is the old hub a boat anchor.....My 75 f-250 every time i put it in the water Id pull the bearings and regrease. what maintance is there with these hubs. Any thing you can tell me would be helpful thanks.
Hubs
I don't think the new unitized hubs can be rebuilt ? I thought they were throw away. I could be wrong ! :wink: Hope this helps Mark L.
PS: Where do you run your 79 in the CMRO mud bogs or private type stuff.
Hubs
PTR,
I am just down the road at Rimbey. Did I buy some D-60 Power Lock differentials from you about 10-11 years ago and you were just building a F-250-350 4x4 in the building that is now the Devon Vet clinic I think.
Mark
Hubs
Ya that kinda rings a bell.
You should reserve Sept.28 or 29/07 an bring your rig out to Rimbey we are having the first annual Mudbogs put on by the new race organization should be lots a fun. Web site www.caraceways.ca . I am really trying to stack the deck with lots of guys with FORD powered units there.
Mark L.
im tring to sell my 79 but if i dont, anything is possible!!!! i work at castrol raceway on friday nights....street cars ,its not the same as mud but still kind of cool. they even bring out some of the faster cars we call them the heavy hitters . its a lot of fun.
mark got it on the head. Unitized bearings are not rebuildable. They are a great convience on the assembly line but they are inferior in a few ways:
You can't rebuild/grease very well
and they usually place the inner and outter bearing closer together. This means when widder tires are installed and the wheel center is moved more outboard of the hub centerline the unit will fail quicker than your old king pin based D60 for instance. this is of course because the wheel has more leverage on the narrow bearing unit.
Hubs
If you want to scrap the unitized hubs, I think Dyna trac makes a conversion to go back to normal wheel bearing and hubs so you can do your own rebuild when you want for a couple hundred bucks. Sometime in the future I am going to buy the kit and have it on the shelf ready to go when one of my unitized hubs go.
FWIW Mark L.
1 - 11 of 11 Posts
