Do NOT install 3" dual exhaust on an RV it will hurt torque and Throttle response AND throttled torque. Actually 2.5" is a bit big for a near stock engine.
Did the previous owner install straight up timing set?
D3 heads need about 35 to 36* total timing for best power. In an RV delay that until about 3200 ish.
If no EGR vac advance limited to about 10 to 13* to start adding more after testing.
180f stat
OEM cam would mean that 12 to 14* initial timing is fine.
RV's are one use where we use the OEM style dual stage advance springs when we set the distributors up on our Sun machine.
Recurve procedure from our porting and BBF info website.
"EMC 2006" 3rd place finisher
Custom ground cams
Customized crate engines
ParklandAutoMachine.com
R-H-P.biz
(253)-988-6648
Parkland Auto Machine
