Questions about vacuum advance units
462 Views 11 Replies 3 Participants Last post by  The Mad Porter
I have the OEM vacuum advance on my '78 F250 with a 460 engine and an aftermarket Duraspark II distributor. The advance unit that came on this distributor was bad right out of the box, so I went back to the original advance unit which also happens to have two ports like this one: More Information for STANDARD MOTOR PRODUCTS VC223
I determined the new one was bad by hooking a MityVac to it and applying vacuum, and the unit didn't budge. I then connected the MityVac to my old unit, and it showed movement with vacuum applied, though it would not hold vacuum and would return to rest if I didn't keep pumping the MityVac.
QUESTION #1: Is a properly functioning vacuum advance supposed to hold steady vacuum, or is the vacuum supposed to bleed off as I described?
QUESTION #2: How does the adjustment using an allen wrench work? Does it bleed off more or less vacuum to control movement? Or does it increase the spring tension on the diaphragm and delay the advance until there is sufficient vacuum to overcome the spring tension? Or does it limit the travel of the advance arm?
QUESTION #3: I believe the second port is for retarding the timing under certain situations. Should it be connected on a '78 F250 with California emissions, and if so to what?
1 - 12 of 12 Posts
1) Advance dashpot is supposed to hold vacuum
2) CCW firms spring and limits travel and advance. CW increases both.
3) Second port in back is vac retard via a thermal vac switch on the Tstat housing for faster warm up of the cats.
Check the advance mechanical curve on the replacement distributor as they are all over the place.
"EMC 2006" 3rd place finisher
Custom ground cams
Customized crate engines
ParklandAutoMachine.com
R-H-P.biz
(253)-988-6648
Parkland Auto Machine
Any advance can should not bleed down if the vacuum level is held constant.
That units diaphragm must be somewhat dry rotted and cracked so it’s well on its way south.
The Allen adjustment simply limits that maximum amount of advance the unit can provide.
With todays fuel and depending on the cam you may be running I would say the bringing in a additional 8 degrees is a very safe starting point and you may be able to add in as much as 15, but above that part throttle ping might kick in and then your added power that you have starts to take big steps backwards, not to mention the harm that can take place in short order.
As far as the retard port it would be my guess that such was needed only to pass emissions which that age vehicle may not have to do anymore.
Thanks that helps a lot. I will get a new advance unit and take it from there. I've been studying up on fine tuning the curve based on David Vizard's advice among others. I do have the lighter advance springs from Mr. Gasket installed.
As talented as DV is he offers no advise relevant to the BBF's timing needs.
OEM 1978 460 with D3 heads will want about 36* total timing in by about 3200 rpm.
Custom ground cams
R-H-P.biz
(253)-988-6648
I have never seen bringing in the timing faster by means of lighter springs and or heavier weights in a heavy street vehicle help much.
If anything I have seen it make the motor ping at part throttle.
Your playing with Fire and if you do not have a knock sensor on the motor then do not go for having the full amount of mechanical timing in before 4000 rpm / well into the Cams peak TQ range.
I was referring to this in particular, quite good info if you ask me:
I agree to a certain extent, particularly if the vacuum advance is left alone to really get the advance curve ramped up at high vacuum. I will eventually be adding O2 sensors, a permanent vacuum gauge, and a tach to my setup to get a better idea of what's really going on. That said I do believe there to be an advantage to the lighter springs if the vacuum advance is "detuned" to avoid the pinging issue at certain load/vacuum situations. The video I referenced above is a great starting point for plotting a curve that maximizes both power and economy by optimizing the vacuum/mechanical balancing act.
The OEM advance curves of the 70's were primarily emissions and warranty oriented.
OEM curves for utilitarian 460's typically brought advance in in two stages starting off aggressively and saving the last 4 to 6* of timing for 3.5, 4.0 and 4.5k rpm just to generalize.
The high compression 429's and 460's of the era offered about 26 to 30* total timing initial + mechanical all in at about 4500.
When bringing in total advance at a lower RPM one must then adjust vacuum advance.
When removing EGR one must remove vacuum advance timing. EGR slows flame front speed.
The leaner the cruise AF's the more part throttle timing needed.
Suffice to say it is a balancing act.
We've been sending out curved DS & points OEM style distributors and custom curving MSD and aftermarket units for 2+ decades now.
The Sun Machines have shown their worth many times over.
Reman and new DS style distributors have inconsistent ignition curves.
Many aftermarket distributors come with heavy advance springs.
Fine tuning the mechanical and vacuum curves to your intended use offers better acceleration, better drive-ability by way of tip in response and transitory response and fuel economy increases.
The key is to attempt to find Max Brake Torque for both WOT and Part throttle operation at various manifold pressures and RPM points.
Basically the analog version of creating a timing map for an EFI system but less precise.
Driving with a vacuum gauge is a really good way to glean insight into a particular vehicles operational behavior.
I drove my 1997 F250 HD 460 EFI for 9 months to get familiar. I then started addressing the fueling and timing maps of the OEM ECM via Tweecer.
I've posted elsewhere about the improvements found even with an OEM engine with good exhaust.
Custom ground cams
R-H-P.biz
(253)-988-6648
All excellent points and I have read many of your posts and have a good idea of the respect you command here. I come from a background of building single cylinder two stroke racing engines, so I have a very strong grasp of the common elements among all forms of ICE's (compression ratios, jetting basics, etc.), with some large gaps when it comes to multi-cylinder four strokes, which I'm try to close. ;-)
One of these gaps is variable ignition timing. The engines we built delivered power over a pretty narrow range, and there was no source of programmable ignition systems at the time. Therefor I learned to squeeze out every ounce of power and reliability by optimizing every other aspect of the engine, particularly carb choice, jetting, port design, intake tract length and configuration (mostly piston port reed valves) and hand make expansion chamber exhaust systems, all of which when working together could more than triple the power of a stock engine.
So yeah, I'm really geeking out on the topic of ignition timing on my truck and trying to become a self taught Sun Machine of my own... ;-)
One thing you said really stood out to me:
I still have my original dizzy and I'm going to compare its springs with what came in the aftermarket unit vs. what's in it now (the Mr. Gasket ones). Those original ones may just end up back in there, we shall see...
Vince in LoCal
Vince in LoCal
The OEM light spring and 1 Mr. Gasket spring typically works well after perch adjustments.
The proper slot width as noted in the link is how mechanical advance is limited.
I provided a link specific to the DS in case you missed it.
Custom ground cams
R-H-P.biz
(253)-988-6648
Now that you mention it I had that setup for a while and it seemed to work well with the 13L slot.
Oh yes thanks for reminding me. I had seen that and when I ordered the new dizzy I believe I bought one for a '75 Tuna Boat of some flavor as mentioned elsewhere. Mine has the 10L and 13L slots and I'm currently on the 10L while I dial in the vacuum advance and sniff out any vacuum leaks I may have. I have another thread about re-bushing the throttle shafts on the 4350 carb for example. (Did I mention I'm in Cali and need to pass smog here?)
Also I just bought these and I'm curious to see what kind of readings I get once I've added O2 sensors into the mix:
Another question... I understand that stock manifold is dual plane, making each side of the carb basically independent jetting-wise. Can I expect to see any noticeable variation between the two banks? (Assuming no other issues on one bank vs the other)
Cali smog should be no issue so long as your initial timing is not too advanced and your AF's idle and transfer are in spec.
In some cases where 14 or 15* BTCD is too much initial for smog simply back it up.
We build 460 EFI crate engines for Cali and all are available as 50 states emissions compliant.
Custom ground cams
R-H-P.biz
(253)-988-6648
1 - 12 of 12 Posts
