on the "Read SPEED at TIRE DIAMETER" part of the calculator, is the speed read supposed to be your speed at the end of the 1/4, or is it just your speed at the set RPM? instructions are: pull slide to set engine RPM at gear ratio. Read speed at tire diameter. dosnt say if its for est 1/4 or not. my guess is its speed at your RPM only, and up to user to figure the rest.
thx guys,
Mark
It is speed at RPM only...The one thing it does not take into consideration is converter slippage if you are running a automatic trans. It does not consider overdrive either.
Hope this helps
