1 - 20 of 57 Posts
Hey guys, its been a long time coming but things are finally starting to roll! It still won't be ready for this season but I should be ready to roll next year.
Engine is a 547ci bbf, old motorsport Aheads with 2.30 intake, ford racing 4 bolt main block. The builder says 900hp+. I dont have cam specs yet as it is still to be ground with a different firing order. Frame and axles come from a '79 F150 and hopefully my old '85 ford body will be made to fit with a shortbox. I do have access to a ranger body but not sure I will go there becasue of the class bump. I will do as much gutting as possible but I need to stay in my class. I'm hoping for the 500 super stock or the 700 pro stock(see what the association says). I will also attach those rules.
I really want to build and run the glide that I picked up, I know the C6 would work but there are others doing it with a glide! I think I have my gear combinations figured out but one day it's a chain drive and then the next it's a t-case so I don't know-gonna need some opinions here.
Dana 44 front, 9 inch rear
Stock axle location in the front and ladder bar/coilovers in the rear. I will be building the housing floater and spring slider too.
I do have Dave Morgans "The Chassis Book" with has been a huge eye opener but still, some of it is greek to me!
Enough babble here is some pictures, I look forward to some good conversation and constructive criticism.
500 Pro Stock
Up to 40” DOT legal tires, or up to 36” cut/modified tires
-Minimal gutting permitted, must have full doors, minimum functional flatbed, body must appear factory
-Electronic fuel injection allowed, single carb/throttle body only
-No vacuum required
-Must run on gas, propane, diesel, no nitrous or alcohol
500 class continued…
-No forced induction unless factory equipped (must be factory turbo for year/make/model)
-Must retain factory frame and axle location
- Stock style suspension for year/make/model, lifts are OK
700 Pro Stock
-Up to 44” DOT legal tires, or up to 40” cut/modified tires
-4 link suspension allowed
-Must run on gas, diesel, propane, no nitrous, alcohol etc
-Single carb/throttle body, electronic injection allowed
-No forced induction unless factory equipped (must be stock equipment for year/make/model)
-Gutting permitted, must have doors or arm restraints
1000 Outlaw
-Any DOT legal tire over 44”, any cut/modified tire up to 44”, all agriculture tires and paddles
Derrick.
Discussion Starter #6 (Edited)
build cont.
Like a lot of people on here right now I'm crunching different gear,rpm combos,MPH vs final drive. I'm working with the glide and just guessing at a 7000rpm max.
39.5" uncut boggers on rear and 38.5"front
5.00:1 rear gear with a np205(divorced), 1.76 first gear=17.25:1 final ratio to come off the line with(47mph top speed), in high gear(1:1)(1.96)=9.8:1 final drive(84mph top speed)
What do you guys think of this, is it fast enough? My other combo looks like this but I dont think it gives me enough off the line.
7.00:1 rear gear with no tcase just chain drive(1.76)(1:1)=12.32:1 in first gear(66mph top speed), in high gear(1:1)(1:1)=7:1 final ratio(117mph top speed.
I dont think I have the power to do it with out a power adder but maybe someone with a similar build will chime in, weight of the unit not sure.3200-3400lbs sound about right? after gutting and with a cage?
Personally, I'd go cut tires and jump to the prostock class, reducing the tire weight and rotating mass pluss adding hook of the line will help. I may consider selling my rear cut 39s if these paddles work out ok. The final drive of 9.8:1 looks alittle better then the 7:1, 10-12:1 is ideal. 5.13 rear would put you right in that sweet spot. With a trans brake and suspension setup well, you should be easily in the low 4s.
As for weight, I havent weighed mine yet, its still heavy but its as good as I can get without spending a pile of money again.
I would definetaley like to be on the list of potential buyers for your cuts!
I have a ford 208 but it doesn't fit between the frame rails. Are the fords as good as the chevs? It would simplify things a bit if I got an adapter from advance but I think I should try to keep as much weight off the glide as possible. I will look into the gearing and see where it takes me.
What kind of times were you running with the 532 last year?
thanks for the extra home work!
Discussion Starter #12
What is out there for master cylinders? I'm pretty sure there won't be enough vacuum to run a stock master. I want to do a rear disc conversion but what are you guys using for a master and did you get rid of the proportioning valve and go with some sort of adjustable unit?
Derrick.
Hey Derrick, sounds like it's going to be a nice light truck when your done!
Is someone in Canada doing your build?
IMO if your going swb and gutted I would opt to get cuts.with your weight and hp it'll make a world of a difference.also could throw on a 300 hp shot and can lend ya my paddle tires since they will be 5 bolt as well! Lol
Sent from AutoGuide.com App
I did a 3.41 on dirt with paddle tires once before as well
Was the 3.41 run with the smaller paddles? What's your guess on time in the mud this year,low-mid 3's?
Hey Myron ,I think I may be mistaken but I thought I seen somewhere in your rules before body/engine swaps are ok and don't get bumped if you keep a ford engine in a ford body? Ie,v8 into a ranger or ranger onto full size frame?
I run a wilwood master cylinder manual brake setup, works fine. I use one of them porportioning valves you can dial in.
Clint - you can use any motor that it may have come from the factory with in the stock and mod stock classes. V8 ranger has to bump up to at least super stock
Discussion Starter #17
Hey Clint,
The engine is being built by the same guy who did Myron's. Precision Race Engines in North Vancouver. He has been awesome to deal with and Myron's 532 was enough proof for me that he knows his stuff. He builds some monster truck stuff too, he sent me a video of one on the dyno.
Lots of offers coming in for tires! I might have to try to rent a set to see which ones I'm going with lol!
Hopefully the water has dried up enough to get the trucks out so I can start working on it. I'll post a pic tomorrow. It's never been that wet where we parked the stuff so it's kinda holding me up.
I need to learn how to drive with this projected power before the nitrous, but you never know:)
Discussion Starter #19
Got a good deal on some cut 39.5's with bead lock wheels! So I'm switching to Dana 60 rear. Cheaper to build the 60 and keep the wheels then to switch the wheels and build my 9". A little unsprung weight back there will help me out too.
Thanks for the stuff Myron
1 - 20 of 57 Posts
