$400.00 takes them that's fifty bux a hole!!
K.B. 138 pistons 0.060 over
rings
Truck rods with A.R.P. hardware, BALANCED and ready to go.
the rings are installed and the pistons and rods are weight matched and assembled (I'm using the crank). This set is ready to be matched to your crank and run! i had this set-up installed in the block but never run, my build changed direction so i don't need them.
Casey
These would make a great street set up under some d0ve heads. Ready to Install!!
375 takes them
