1 - 20 of 128 Posts
Fully remanned and recurved to application.
I disassemble, double check, curve to applcation and reassemble.
Curve is set on a sun distributor machine. In addition vacuum advance dashpot is set per application.
Cost is $144.95 plus shipping.
Warranty is lifetime.
8)
Scotty,
Can you do one and ditch the vacuum advance stuff for my WOT mud bogger? Basically make it a mechanical advance setup?
kjett said:
Scotty,
The vacuum advance can simply be left disconnected. Its arm positions the breaker plate. It could be tacked for additional strength. I can set up an advance curve with a very small amount of mechanical advance and a good amount of initial.
I would just need your build specifics.
I have run these distributors to 700 Hp with no issues and found no additional power changing to an MSD unit which utilises the same pick up and reluctor assembly.
8)
grand_marquis_gt said:
Email sent 8)
Email received and a reply sent... :)
Thanxxx.
8)
Would it be possible to send you a dizzy and have it worked over or used as a core? I have a couple collecting dust and Id rather see them get redone and used that just keep sitting.
I can utilise the cores for core value against the purchase of a remann unit. This is provided they are in together condition.
You could send up to 3 in a flat rate usps box.
I dont rework the originals as it cost much more than just buying the remans in bulk.
Telephone me for more information. 253-988-6648.
a
How about a locked unit for a crank trigger ??
Do you feel comfortable using your distributor to spin the oil pump in a 900 HP motor ?? (Using an aftermarkrt drive shaft) - Have never seen any info on where the stock shaft in the distributor runs out of gas
Re: a
This is a reman stock replacement distributor. I dont think its use is appropriate for that appication to be honest.
8)
Discussion Starter #12
Just Brian said:
Hi Scotty,
How much to ship to New Zealand.
Cheers Brian
If you still need help with this PM me....
8)
Discussion Starter #16
IndyPete said:
Do you still sell these? Haven't heard anything from ya.
Sorry fellas, it is best to email me. I lose track of the auction posts.
Thanxxx.
8)
Discussion Starter #17
ttt
bump
8)
Discussion Starter #18
TTT
Bump
8)
Discussion Starter #19
Distributors are still available.
$149.95 shipped to your door via USPS priority mail....
Can upgrade gear to bronze for roller cam compatability $call.
:D
Can you recurve the older style points distributors? Ive got one I converted over to an accel non points. Id like to keep the car as stock appearing as possible
1 - 20 of 128 Posts
