Custom ground solid roller cam spec'd by Scotty J at RHP used one season before going to a bigger cam. $175
Specs. are as follows;
Intake & Exhaust
Lobe Center Sep. = 110.1 Cam Deg
Valve Overlap = 49.3 Crank Deg.
Intake
Valve Opening = 24.6 BTDC
Lobe Center = 107.4 ATDC
Valve Closure = 61.9 ABDC
Duration = 266.3 Crank Deg.
Max Cam Lift = .40323 IN.
Net Valve Lift = .69759 IN
Lobe Area = 36.74 IN deg
Exhaust
Valve Opening = 67 BBDC
Lobe Center = 112.8 BTDC
Valve Closure = 24.6 ATDC
Duration = 271.6 Crank Deg
Max Cam Lift = .40055 IN
Net Valvelift = .69295 IN
Lobe Area = 37 IN Deg
PM with any questions. Pictures available upon request.
Also have a Coan Engineering converter listed on EBAY, auction #270190514268
Alan
