for sale in the state of South Carolina
1 dove 4 bolt block std , pick-up only as is $600
1 new lunati roller cam 640650 lift Voodoo and nice used set of comp lifters $375 shipped cam is new 64030 grind summit sells for $319
1 67/8 fastback body tubbed out with 67 title and plate with a 671 blower and 513 motor all forged and polished set up for street w/4;11 spool ,c6 2000 stall ,disc ft brks ,body work 80% complete needs to be primed and blocked one more time .Backhalve car with factory dash and doors and frt end .Ladder bar suspension coil overs very nice job .Must see to appreciate !! Asking for $18,000 or best offer . CASH TALKS so make an offer on this car .It has almost new Mickey T streets on the rear ,centerline wheels ,needs frt tires they are pumped up but wouldnt run from age .look at other posts for pics
1 DIVE BLOCK $125
1 set D3 heads $100
1 460 crank turned 30/30 with bearings $125 needs to be cleaned up from sitting
Discussion Starter #2
bump
bump
with the voodoo cam and lifters. how used are the lifters? can I use this cam and lifter set up in a stock motor? will I have valve clearance problems with flat top pistons?hh
