1 - 6 of 6 Posts
Like I said above I dont know what ratio they are..........Tell me how to tell with out them being marked and I will check.
the wear on the rocker is what happens when the pushrod slips outa the pushrod pocket and digs into the rocker... which pushes the rocker off the valve stem and onto the spring or between the springs, then the motor keeps running and basically the pushrod pushes the rocker up and down still which gives u the dig marks/wear spot.
Id be very weary of putting that one rocker on my motor. If the other rockers are good u could buy his set and then purchase a seperate rocker from summit and finish the set.
They look like harland sharps, not sure on the ratio tho
1 - 6 of 6 Posts
